is it possible?
Old May 3, 2004 | 07:35 PM
boond0cksaint's Avatar
boond0cksaint
is it possible?
is it possible to be able to prime an oil pump, but for it not to hold pressure? 2nd time i put a new oil pump in(same one) and still not getting pressure. pulled the dizzy tonight and put an extra shaft in the end and its snug as a bug. motor is starving for oil. when i had the old pump in before the swap, i would get 50lbs at startup cold. i think i might get another pump. any suggestions on what kind? running a 88 f-150 2wd, 302, c-6. tired and ****ed off, but cant give up yet though. have another motor to put in but am keeping that for my 1970 1/2 falcon. thanks
Old May 3, 2004 | 07:48 PM
Fordtech1's Avatar
Fordtech1
By priming you mean inserting a shaft into the pump and spinning the shaft with a drill (with dist. out of course)?
Old May 3, 2004 | 07:55 PM
boond0cksaint
no, pouring oil in the input and spinning the shaft by hand,did the same way on my mustang and no problems, but also got that pump from a machine shop.
Old May 3, 2004 | 07:59 PM
Fordtech1's Avatar
Fordtech1
Ok, but now the pump is back in the engine? Spin the shaft with a socket and an extension on a drill and you should feel the drill drag down when the oil pressure comes up, then reinsert the dist. and recheck when the engine fires up.
Old May 3, 2004 | 08:05 PM
boond0cksaint
ok, this pump gives me about 40lbs @ 2500 rpms and then 5 lb at idle almost bottomed out. and now my lifters are tapping at idle, like oil starvation. do you think i still need to do the drill prime?
