bronco help
Old May 3, 2004 | 05:54 PM
mixed_up101's Avatar
mixed_up101
bronco help
ok my engine is not starting, it has 2 gallons in the tank, is this not enuff that the pump cant pic it up? both pumps are working. i prime and it will run until the prime is gone, i think it may be that none are the inkjectors are firing fuel. is this possible, and how do i fix it, i really need help
Old May 7, 2004 | 03:31 PM
Copper93's Avatar
Copper93
How are you priming it? Pull the fuel line off and make sure fuel is getting to the engine. Could be a clogged fuel filter or fuel line.
Old May 7, 2004 | 07:04 PM
TUFFY's Avatar
TUFFY
try a pressure test to see if in fact the fuel pumps are working or not btw i had an 79 f250 which had to have about 3.5 gallions for the fuel pump to pick it up plus if it ran out of gas you had to suck on the fuel line to get the pump to work at all .
Old May 7, 2004 | 09:30 PM
daerhldgs2's Avatar
daerhldgs2
you say you have injectors so see if there is gas/pressure at the schrade valve on the injector rack, if so the you may have a fault in the wiring to the injectors.
Old May 7, 2004 | 10:14 PM
mixed_up101
Red face ooops stupid me
just checked the gas lines, there was a kink in one of the fuel lines above the tank
