Flame throwers
Old May 3, 2004 | 02:37 AM
Budly's Avatar
Budly
Flame throwers
I have seen many people ask how they are made on here without an answer so i thought i would ask how its possible. Keep in mind, i am from SD on a reservation where emissions laws are as fictional as a brave frenchman. any ideas, if possible give for fuel injected and carburated. thanks
Old May 3, 2004 | 08:51 PM
Budly's Avatar
Budly
obviously its a procedure above the knowledge of this forum
Old May 5, 2004 | 02:23 PM
nastruk95's Avatar
nastruk95
it will never work on fuel injection unless you run a seperate fuel line right into the exhaust tip or use propane. the efi runs to lean no matter what you do. carburated is easy, just turn off the key pump the gas and restart an you might get an explosion with that flame, just be careful because you can get arrested if you do it in front of a cop.
Old May 5, 2004 | 03:45 PM
RawPower's Avatar
RawPower
Its a do it yourselfer job...
These are not plans and I dont know what Im doing, so get some real advice before you do it....
Run a line into your exhaust about 1-2" from the end, with an electric one-way valve 6 inches-10inches from the end of the line. Id put your propane in your bed (what do you drive). Id also put a one-way valve at the end of teh tank that shuts off automatically, just for precautions. After the tank youll need a valve to control the PSI of propane, somewhere that its accesible. Wire the electric one way valve to the same switch as hte ignitor (continuos spark, preferably toggle switch).
Old May 5, 2004 | 04:30 PM
95-F-350-4x4's Avatar
95-F-350-4x4
Or you can buy a kit!
http://www.autoloc.com/products/flame.lasso
Old May 6, 2004 | 04:00 PM
jimbo81587's Avatar
jimbo81587
i got two good sites for you guys interested like me. I have yet to try this method:
http://www.brayarch.com/~kevin/flame/flamekit.html
Also here is a site of some videos of a kit that sells on ebay so you will see what kind of results you will get
http://venomavenger.gq.nu/TORCH/Torch.html
Mostly what you need is some kind of pulsating power source to power a coil for each exhaust pipe which causes a spark plug to spark continuiously to ignite excess exhaust gasses.
