Oil Change
Old Jun 1, 2002 | 07:03 PM
TurboTuff's Avatar
TurboTuff
Oil Change
Hi there...I'm new to Deisel and need some info.
I'm doing a oil change and need to know the oil amount in litres.
I run a 1994 F250 XLT 4x4 Turbo Deisel with a V-8 7.3 engine.
Can anyone help me out...the book that Ford gives with the truck keeps telling me to refer to the Maintenance Supplement???
I don't have this...
Old Jun 1, 2002 | 07:06 PM
MartyB's Avatar
MartyB
Oil Change
14 quarts if you change the filter. Sorry, but you'll have to do the conversion. Should be about 12?????
Old Jun 2, 2002 | 12:04 AM
Quadzilla's Avatar
Quadzilla
Oil Change
I think it's a little more than 13, something like 13.23. Do you buy motor oil in liters where you are? I assumed, mistakenly I guess, that the motor oil manufacturers packaged oil in jugs that were 1 quart, or 1 gallon, then showed the metric equivalent on the side of the jug.
A gallon of milk is 3.78 liters, so using that ratio, I figure 14 qts should be 13.23 liters.
I hope this helps.
Old Jun 2, 2002 | 01:25 AM
TurboTuff's Avatar
TurboTuff
Oil Change
There is no SAE markings on our OilJugs.
Just Metric...
I dropped the old oil and got about 11 litres thats with the oil filter out as well.
Putting the new filter then topping it up with fresh oil I used about 11 litres.
I will check it in the morning after running it for a bit.
I also replaced the air filter at the same time.
I went to drain the water out of the FUEL FILTER but can't seem to see a shuttle **** or tap to open and drain it.
The drain pipe comes out of a brass ring that threads in and out but loosening this ring does not drain anything out.
How can I tell if it needs draining?
1994 F250 SC XLT 4x4 Turbo Deisel
7.3 Limited Slip 4.10's
Old Jun 2, 2002 | 08:00 AM
powerstroker250's Avatar
powerstroker250
Oil Change
You should have a puddle of fuel on the floor. The drain valve should be on the right rear of the fuel filter bowl if your truck is a Powerstroke. If not, I'm not familiar with the early turbo diesels.
Les
Old Jun 2, 2002 | 01:13 PM
TurboTuff's Avatar
TurboTuff
Oil Change
No puddle of fuel...
And no drain either???
Anyone know where this is on the filter or how to drain it?
Old Jun 3, 2002 | 02:36 PM
spartamouse1's Avatar
spartamouse1
Oil Change
