clicks upon startup
Old May 2, 2004 | 05:59 PM
nibiru's Avatar
nibiru
clicks upon startup
Me again : Since I am here
93 F350 7.3L
as soon as I turn the key it clicks and continues to click for the first 30-45 seconds of running. Volt guage jumps as well while clicking.
i was searching the board to see if it may be cam sensor
Could this be glow plug relay. truck is very hard/long starting when cold
suggestions
Please and thanks
peace;
nib
Old May 2, 2004 | 08:41 PM
rancherman84's Avatar
rancherman84
well a 7.3 idi dosent have a cam sensor.it sounds like a controller,when you turn the key on it should,make the WAIT TO START light come on,then the controller will start to cycle the glow plugs for a few seconds,but 30 to 45 is to long,that long will burn out your plugs.
Old May 2, 2004 | 10:06 PM
nibiru's Avatar
nibiru
Rman84
The wait light comes on and depending on the temp lasts for a few seconds- yet the clicking - which is not uniform - continues and really only does this upon first start - or first cold start
When hood is open I can hear this clicking clearly as it seems to be coming from front/top of engine.
I got the idea of cam sensor from another board where someone had the same problem / same year and response was check the cam sensor
Peace:
nib
Old May 2, 2004 | 10:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Have you checked the glow plugs for bad ones?
Your glow plug relay is in a box that should be on the drivers side rear of the intake manifold. The box is about 3 by 4 inches with the glow plug harness wires going to it.
The relay is under the plastic lid, the controller is under the relay.
