banks exhaust
Old May 27, 2002 | 01:03 AM
71mustang's Avatar
71mustang
banks exhaust
Has anyone installed a banks monster exhaust on a 98 or newer superduty? If so how hard was it and did you have any problems?
Cody
Old May 27, 2002 | 04:02 PM
LW555's Avatar
LW555
Post banks exhaust
[updated:LAST EDITED ON 27-May-02 AT 05:04 PM (EST)]I didn't do the Banks, I did the ATS, but here's some info that might help you anyway. The whole thing is pretty easy, putting on the new downpipe is the hardest thing. Get someone to help you, believe me it will save time. I tried to put the new downpipe on myself, struggled for an hour with no luck. Then I got a friend to hold the pipe for me from underneath and it took 2 minutes.
When you remove the old pipes, put some lube on the end of the hanger ends, it will help them slide out of the rubber biscuits. Also the weight of the exhaust is what keeps those hangers from sliding out, so if you push up on the parts to relieve the weight, they slide out easier.
Also removing the stock downpipe can be tricky, you have 2 options:
1 - cut it in half. That's what I did, used a sawzall, took me only a couple minutes.
2 - remove the transmission support crossmember. That means you have to find a jack to support the tranny, and removing the crossmember is a pain. But if you want to keep the old pipe, you gotta do it.
The ATS downpipe is really short, but the Banks downpipe looks longer, like the stock one. If that's the case, then you might have to remove the crossmember anyway to install the Banks.
Also, before you install the new downpipe, open up the marmon clamp (the ring clamp that holds the pipe onto the turbo) all the way, it goes on easier. Good luck & have fun!
Old May 28, 2002 | 04:25 PM
Ghostrider304's Avatar
Ghostrider304
banks exhaust
>problems?
>Cody
I've had my Banks Monster Exhaust on my truck for about two weeks now and I love it. It was a snap to put on just need a buddy and a few common tools.
As for the down pipe cut the old one the new one will fit with out removing the tranny crossmember.
I now have a better take off power and I'm seeing a fuel savings as well. And to top it off it has a good sound now.
Well I hope this helps in some way. Let me know what happens with yours!
Will-
Old May 28, 2002 | 11:14 PM
TKONO's Avatar
TKONO
banks exhaust
William, I live in St.Louis and was thinking about going with the Banks for my truck. Is there any way I could maybe check yours out sometime? If so, send me an e-mail (TKONO(No Email Addresses In Posts!)) Thanks,
John
Old May 29, 2002 | 10:32 AM
Ghostrider304
banks exhaust
>John
Well I'm working nights for the next two weeks so I'll get with you when I'm on my afternoon shift.
Where in St louis are you at anyway?
Will-
Old May 29, 2002 | 10:34 PM
TKONO's Avatar
TKONO
banks exhaust
William,
I live in Fenton, and work in Kirkwood, but I am all over town throughout the week. I am a roaming mechanic for a painting company. Mine is a 99 F-350 xlt Lariat 4x4 x-cab Dually and I want to spruce it up a little. I'm in no huge hurry though, whenever would be fine.
John
Old Jun 6, 2002 | 08:53 PM
theologian's Avatar
theologian
banks exhaust
Old Jun 7, 2002 | 07:35 AM
99f350's Avatar
99f350
banks exhaust
I installed the Stinger Plus kit on my 99 F 350 4x4, crew cab off road. Took about 2 hours for the exhaust only. The old exhaust came out in one piece. This was no problem as my truck was high enough without jacking it up. The v clamp at the turbo was hard to get off. You will have to drop the cross member at the trans. I used a 2 ton jack but was barely sufficient to take the weight of the trans, transfer case and back of engine. Be careful as this could be dangerous if you loose control of the weight. Lastly, start at the turbo and work back. My son worked at the rear end and I worked at the front. We could not fit the center piece in without taking the tail pipe back off. The center extension has to be cut to fit to proper length. A horizontal band saw cut the stainless with ease.
Steve
Old Jun 11, 2002 | 12:54 AM
Ghostrider304
banks exhaust
>Steve
Steve,
Can you fill me in on what the stinger plus kit comes with. I'm hoping to buy some other iteams from Banks, but not sure what mite be good.
How is your truck running since the install?
Thanks,
Will-
429unibody
2009 - 2014 F150
Nov 25, 2010 01:00 PM
wallyrock
Computer Chips & Tuners
Jun 26, 2009 09:37 PM
ldfry001
Jan 25, 2008 09:08 AM
pkenn7
Nov 26, 2007 09:57 PM
