code 67
Old May 2, 2004 | 10:54 AM
bricktop's Avatar
bricktop
Unhappy code 67
hey there,
i'm new here so please bear with me. I'm getting a code 67 in the KOEO test. The book says it's a neutral pressure switch malfunction. Where is this switch and what does it do? How would I go about testing it? The truck is an '86 ranger 2.9, manual trans, stripped model with a utility bed. Occasionaly it bucks on acceleration and has a constant muffled backfire under deceleration (sounds like a coffemaker running out of water). I have replaced the idle air valve, egr,egr position sensor, egr vacuum control valve and 02 sensor. I get an 11 on the continuous memory and have not run the timing or KOER because of the 67 code. Any help is greatly appreciated as I am trying to smog this thing in Ca.
Thanks, Chris
Old May 2, 2004 | 11:07 AM
el conquistador's Avatar
el conquistador
did you have the a/c on during the testing? that will cause code 67.
Old May 2, 2004 | 12:48 PM
bricktop's Avatar
bricktop
it doesn't have A/C. that is why it's so puzzling
Old May 2, 2004 | 12:58 PM
Fordtech1's Avatar
Fordtech1
Did you have the clutch pushed in?
Old May 2, 2004 | 01:16 PM
87 XLT's Avatar
87 XLT
Iwould'nt worry about the 67 for now. The popping while coasting does sound like retarded ignition timing. Warm the engine up, remove the spout connector & check for 10 degrees BTDC with your timing light.
Old May 2, 2004 | 04:02 PM
bricktop's Avatar
bricktop
The 67 went away after it warmed up. I ran the timing check-it's O.K. then the KOEO and got a 25 code-knock sensor. Would a faulty knock sensor put the computer in some kind of default or "limp home" mode thereby causing the popping under deceleration?
Old May 2, 2004 | 08:28 PM
Ken00's Avatar
Ken00
A faulty sensor will cause the ECU to use a default value. A bad KS would most likely cause retarded timing, loss of power or pinging.
Old May 3, 2004 | 07:56 AM
bricktop's Avatar
bricktop
Thanks everyone for your help. This is a great site and a great source of information.
Thanks again,
Chris
