valve timing question
Old May 2, 2004 | 10:36 AM
old hippy's Avatar
old hippy
when the marks on the cam gear and crank gear are aligned isn't the mark on the balancer supposed to match up to tdc on the timing cover? also, there seems to be two different sets of marks on the cover. one bolts to the cover and has notches cut into it and the other is cast into the cover.which one do i use? '85 f150 with carb. any replies greatly appreciated.
thanks
Old May 2, 2004 | 06:38 PM
dj8667's Avatar
dj8667
My 86 carbed uses the one that bolts on the cover.
Old May 4, 2004 | 09:57 AM
old hippy's Avatar
old hippy
thanks for the reply dj8667. when the marks on the gears are aligned the mark on the balancer lines up with 30 degrees before tdc. does this mean that it jumped timing?if it did, i'm danged if i can see how or why.both gears look ok to me and the truck seems to have only about 150,000 miles on it.thanks for any help.
Old May 6, 2004 | 10:41 AM
old hippy's Avatar
old hippy
yippee!! i don't know how i missed this thread started by cdherman https://www.ford-trucks.com/forums/s...d.php?t=237193
answered all my questions thanks to a reply by faroffthetrack. i didn't know the balance pulleys tended to spin on the 300's. but this only my second ford 6 banger,,, live and learn.
