vaccuum diagram needed
Old May 2, 2004 | 09:01 AM
mudking77f150's Avatar
mudking77f150
i need a vaccuum diagram for a 1977 400 engine. when i got the truck it was all cut up. i would like to hook everthing back up the way it should be, except for hooking up the dis. to a vaccuum switch. i would rather have it to the carb.
thanks
Old May 2, 2004 | 03:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hooking the distributor up thru the vacuum switch is one thing you SHOULD do!
We used to have a source for vacuum diagrams but the site is under construction and many of them are not available. You can check it at: http://www1.autozone.com/
Old May 4, 2004 | 03:43 PM
mudking77f150
vaaccum needed
thank you for the info. i'm going to that web site now.
