76 f250 timing
Old Apr 30, 2004 | 11:44 PM
oldblue31's Avatar
oldblue31
76 f250 timing
Ive` got a 76 highoy with a 39.0Edelbrock,holley 670 carb and msd ignitoin
just wondering what the best timing podituis
Old Apr 30, 2004 | 11:50 PM
gtex's Avatar
gtex
advance until it runs well! seriously, advance it to about 12 for a mild-med cam. With a slighter hotter cam, you may go even farther. I'm running about 16 BTDC. Just keep listening for pinging at the higher revs. Are you running a stock or Ford distributor with the MSD, or are you running the MSD billet FE distributor?
Old May 1, 2004 | 07:47 AM
oldblue31's Avatar
oldblue31
running mild cam and all msd.pro billet distributor and msd6 box
Old May 1, 2004 | 10:11 AM
gtex's Avatar
gtex
The MSD Dizzy, does not have the vacuum advance. From what I understand, it really likes to have a higher initial advance.
Do you know what springs and stop bushings are in there? Do you have the manual and the other sprigs and bushings? It' pretty easy to change those and get a different advance ramp and max advance setting.
Old May 1, 2004 | 11:10 PM
oldblue31's Avatar
oldblue31
both heavy silvers. I believe i have the black bushing installed. I have changed it all several times trying to find the right curve and just cant seem to figure out the right combo
