I was checking out a couple 115V MIG (flux core really) welders on clearance. I need a light duty welder for repairing rust holes in my truck. If anybody has owned one (Chicago Electric) tell me what you think of it. Another question is one has a manual wire speed adjustment, and another one has an automatic, how does that work and if you know how well does it work. I have used all sorts of welders in the past (MIG, Oxy-Acet, Stick), just never seen an auto speed adjusting type. Has anybody used a Campbell Hausfeld MIG? Saw these at Walmart, with a 5 year warranty.
Phinxter
Even though I haven't purchased a welder from Harbor Freight, I have bought other things. I have to be honest with you, most of it is really crappy stuff, shabbily made, inferior materials, etc. I bought some wood bits there a while back, couldn't even drill hard woods. Pure junk. On the other hand, everything I have ever bought with the Campbell Hausfield name has been good stuff. My wire feed welder is a Lincoln. My 2 HP air compressor is a C. Hausfield that I have had for 10 years. Never a problem.
the campbell/hausfield welders are good if you get the $20.00 wire spool and not the $7.00 spool. paid $100.00 for mine a year ago. so far have run all my exhaust on 3 projects,so the welder has saved me money.
Get a MIG welder that uses .023/.024 wire and a gas bottle. Flux is great for some things, but, for sheet metal a gas MIG welder is much better and will not blow through sheet metal and exhaust tubing like flux can. Plus, gas MIG produces a MUCH nicer weld.
Another question is one has a manual wire speed adjustment, and another one has an automatic, how does that work and if you know, how well does it work.
I would go with the manual wire speed. so you can fine tune the wire speed to your heat setting. Somtimes I've had to really crank back the wire speed to fill some holes. I have a Snap-on 140A Mig/ Dc tig and love it. It was expensive but they had a special going on and I got $280 back in tools.
Reason: not finished
I just recently bought a Lincoln 175 plus. It requires 220 but does a great job whether welding body panels or general welding up to 1/4". I have no complaints so far.
We have the Hobart H135 at work, and its a really good welder, it can do light duty stuff like sheet metal, and we havent had any problems with it at all. itll run ya a lil over $300
how long have you had it and how much have you used it, also what model is it
