Wiring Tailights
Old Apr 30, 2004 | 09:48 PM
murphy's Avatar
murphy
Wiring Tailights
How do I wire the taillights on my F100 ? I've identified the 2 turn signal wires and the wire energized by the headlight switch(total of 3 ). If I split the "headlight" wire, won't that cause the turn signals to act as 4 way flashers. There's only 2 wires leading from the tailight bulb. Also which wire should be used for the brake signal ? I've probably made this more difficult than it should be, thanks for any info.
Old Apr 30, 2004 | 09:58 PM
manglass's Avatar
manglass
You didn't mention the year or if there were separate turn signals so I'm guessing a little here. The tail lights should have 2 filaments in each bulb and a wire for each. The ground is through the chassis. Split the wire from the headlight switch as you suggested and wire to the dimmer filament in each lamp. Each turn signal wire goes to the brighter filament in the lamp. The brake lights should also work (through the turn signal wiring). Hope that helps.
Lou
Old Apr 30, 2004 | 10:04 PM
murphy's Avatar
murphy
its a 60 f100, thanks lou
Eddie Rust
Jun 25, 2014 06:46 PM
uglytruck1403
Electrical Systems/Wiring
Sep 20, 2013 03:53 PM
thenukemaster
16
Aug 30, 2013 05:32 AM
greeneon_01
Apr 26, 2009 09:53 PM
mikes66
Nite, Nascar & Other Limited Edition Ford Trucks
Jul 31, 2001 10:47 PM
