Missing when warm
Old Apr 30, 2004 | 08:32 PM
vf78ot's Avatar
vf78ot
Missing when warm
I have a 1991 F-150 4X4, with a 5.0, 302.
I have done the following to it:
New Spark Plugs
New Wires
New Vacuum Lines
New Air Filter
New Fuel Filter
New Dist. Cap
New Coil
New Rotor Button
Now the problem is that even after I have done all this, the truck is still "missing" when the engine is warm. It is not a vibration, is it a miss. When the truck is idling it runs fine, when you "rev" up the motor it does fine. When you are driving, and cruising along motor begins missing, but when you step on the gas and the truck goes into "passing gear" it goes like a bat out of heck, with no miss, but as soon as the slow down and cruise and try to keep up a good speed, it begins missing. It seems as if the motor is loading up. Like it is flooding even though it is not carburated.
HELP HELP HELP
Old Apr 30, 2004 | 08:54 PM
countrygirlfrommaine's Avatar
Red face Me Too
i am having the same problem only mine has gotten worse it stalls while it is idiling. i am told it is the mass air flow sensor .does anyone agree.please help.
THANKS
Old Apr 30, 2004 | 09:51 PM
mueckster's Avatar
mueckster
Could be a bad spot on the throttle position sensor. '91's don't have the MAF sensor.
Old Apr 30, 2004 | 09:53 PM
mine is a 95 forgo to mention that
Old Apr 30, 2004 | 11:58 PM
vf78ot's Avatar
vf78ot
I forgot to mention, we also have also put in a new throttle position sensor.
Old May 1, 2004 | 12:19 AM
MustangGT221's Avatar
MustangGT221
Please title threads based on their subject so it's easier for people to find when using the search function in the future. Thanks.
Old May 1, 2004 | 08:48 AM
EPNCSU2006's Avatar
EPNCSU2006
Do you have any codes in the computer?
Old May 1, 2004 | 09:37 AM
Slade901's Avatar
Slade901
New Spark Plugs
New Wires
New Vacuum Lines
New Air Filter
New Fuel Filter
New Dist. Cap
New Coil
New Rotor Button
HELP HELP HELP
I would do this in the following order.
Put a bottle of Fuel Injector cleaner in a Full Tank of gas. Test it.
Put a new Fuel Filter. Test it.
Replace the Ignition Module. Test it.
Old May 1, 2004 | 09:40 AM
Slade901's Avatar
Slade901
THANKS
I would clean your IAC (Idle Air Control solenoid) if it has one. Clean it with a throttle body cleaner and a brush, clean the spot where you remove the IAC from the Throttle Body. If that does not work, replace the IAC.
Old May 1, 2004 | 10:18 AM
chrisbeery's Avatar
chrisbeery
Check for codes and report back...
Old May 1, 2004 | 10:26 AM
chrisbeery's Avatar
chrisbeery
Also, even tho you have new wires, check to see you're not getting crossfire. Keep wires separated as much as possible, listen for "snapping" noise of spark crossfire under the hood, and in a dark garage, mist wires lightly with a spray of water, and look/listen for sparks. Even tho my wires ohm'ed out OK, I was getting some crossfire from them.
Old May 1, 2004 | 01:22 PM
vf78ot's Avatar
vf78ot
Could it be fuel injectors going bad?
Old May 1, 2004 | 01:42 PM
Fordtech1's Avatar
Fordtech1
Yes, it could be the injectors, could be a lot of things, did you pull the codes???
Old May 1, 2004 | 10:24 PM
vf78ot's Avatar
vf78ot
Sorry...but how would I go about pulling the codes, explain, so that I may check it out.
Old May 2, 2004 | 12:05 AM
EPNCSU2006's Avatar
EPNCSU2006
go to http://fordfuelinjection.com and click on "Getting Codes"
jt95
Oct 19, 2015 12:28 AM
AWC
1983 - 2012 Ranger & B-Series
16
Oct 8, 2014 12:35 PM
Michael Ward
1997 - 2003 F150
Jun 11, 2014 09:58 PM
eightysix
Modular V8 (4.6L, 5.4L)
Aug 9, 2004 04:53 PM
JEFFREYC
Apr 7, 2003 06:26 PM
