Head Torque for 4.2
Old 04-30-2004, 06:34 PM
Binder Guy's Avatar
Binder Guy
Binder Guy is offline
Head Torque for 4.2
I am looking for the proper torque for the heads on 4.2 V-6's, a friend of mine has had one rebuilt, and doesnt know the torque specs.... found the specs but the book I found listed the head bolt torque at 36 ft-lbs... that seems awful light. What do you guys think?
Thanks for any help.
Tim
Old 05-04-2004, 04:55 PM
F1Frankie's Avatar
F1Frankie
F1Frankie is offline
Sorry. i hate to leave you hanging with no replies...but I really have no idea. I would suggest going to your local library and checking out a Chilton or Hayes if they have one. Most do. Sorry I am not much help...
Old 05-05-2004, 01:03 AM
kellendv's Avatar
kellendv
kellendv is offline
torque specs: FT-lbs unless otherwise indicated
cylinder head bolts (oiled)
step 1...............................168 in-lbs
step 2...............................29
step 3...............................36
caution: when following the torque sequence for the V-6 engine, at step 4 do not loosen all the bolts at the same time or the gasket will not seal properly. loosen the first bolt in the sequence, tighten it to final torque (steps 5 and 6) then go to the next bolt in the sequence, loosening and tightening the bolts untill the sequence is completed.
step 4..............................loosen 3 turns ( do not loosen all bolts here. follow caution)
step 5
long bolts..................30 to 36
short bolts.................15 to 22
step 6(all bolts).................tighten an additional 175 to 185 degrees
get yourself a haynes manual! as i was told to do recently.....they are invaluable, and interesting
Old 05-05-2004, 08:20 PM
Binder Guy's Avatar
Binder Guy
Thanks Guys
I will forward this to my friend, and see if he has come up with some specs as well.
Thanks
Tim
Old 06-16-2017, 03:58 PM
Angel Manuel's Avatar
Angel Manuel
Angel Manuel is offline
Go to Google and ask about expc 4.2 torque and they will tel you all the expc For your engine
Tim
I am doing my 1998 F 150 4.2 v6 now,so I went to Google and write my truck year,model and make and ask for the torque especifications and the show me all of them.you will need a degree tool to do the job.hope I help you somehow
workingdan
2017+ Super Duty
27
10-27-2020 09:06 PM
joe blow
08-25-2017 07:46 AM
1972fordhighboy2
04-12-2017 07:03 AM
49f3dls
21
08-13-2016 10:27 PM
canuck2a
2009 - 2014 F150
06-12-2016 11:42 PM
Quick Reply: Head Torque for 4.2
