1978 - 1996 Big Bronco
Locking hub conversion???
Old Apr 30, 2004 | 02:42 PM
BroncShane's Avatar
BroncShane
Well, this is it! My buddy and I are going to attempt to change my auto hubs to Manual this weekend. I got a set of Warn's.
Somebody told me that I might need to change the gear in the Transfer case like they had to on a GM. Does anybody know if this is the case?
Also, the guy at the parts store said I would need a "Conversion Kit", Is this true?
Thanks
Old Apr 30, 2004 | 02:57 PM
88bronco351's Avatar
88bronco351
How many screws hold on your Auto Hubs if it is 5 screws you DO NOT need a "Conversion Kit" 3 Screws you need the conversion kit, I change to warns a year ago man these things are awesome money well spent, dont know why you have to change
the gear in the transfer case never heard of this
Old Apr 30, 2004 | 02:58 PM
killerklown's Avatar
killerklown
I didn't have to chande any gears.
As far as the conversion kit, it depends on which auto-hubs you had. Mine is a '95, so right on the auto-hub there are (3) screws holding the cap on. If this is what you have you will need the kit. I also wound up buying a few special tools to make it much easier, however I have since found you can rent these tools. Do a search on this site, you will find comprehensive instuctions, pics., and other info.
good luck
Old Apr 30, 2004 | 03:13 PM
BroncShane's Avatar
BroncShane
Thanks for the info.... I wanted to change to Manual hubs because Mine don't always lock. Looks like I can take back the conversion kit and buy beer with the money.
Old Apr 30, 2004 | 07:30 PM
Tidybowlman0's Avatar
Tidybowlman0
Use this link it will help
http://www.off-road.com/ford/bigbron...balljoint.html
Old May 5, 2004 | 05:16 PM
bigric's Avatar
bigric
http://www.superford.org/registry/ve...=17888#content
There's your pre-'95 conversion guide. And, no, there's nothing to be done to the xfer case. This conversion should take you about 20 minutes.
Old May 5, 2004 | 06:18 PM
BroncShane's Avatar
BroncShane
Thanks
Hey guys and gals, thanks SO much for all your help.
The switch was done and beer was drank.
