Sponsored by: Real Truck
simple front spring question
Old Apr 30, 2004 | 01:31 PM
sdumond's Avatar
sdumond
97 F250 7.3L HD 4x4 crew cab, with the leaf sprung IFS. I want to order new front springs to level the truck. Would F350 front springs bolt up and would they raise it enough? Or should I go after market and if so with whom?
I've also heard that swapping in an F350 solid front axle is a simple bolt on application with very little to no modification. Is it?
Old Apr 30, 2004 | 07:26 PM
CAT_man_963's Avatar
CAT_man_963
If you raise the front of your ifs truck you're gonna have to get some alignment brakets to lower the axles down so the tops of the tires don't lean out. As far as the solid axle front end, check out ORU www.offroadunlimited.com - I kind-of think I remember reading some info about it there?? Maybe even a kit minus the axle?? IMO - that would be the way to go - much simpler suspension lift and beefier front end!
Old Apr 30, 2004 | 08:09 PM
sdumond's Avatar
sdumond
thanks
thanks CAT_MAN, its what I thought but wanted to get someone elses opinion. You know how it is, i dont know what i know until someone else tells me i know it.
thanks again.
