ignition ground?
Old Apr 30, 2004 | 10:59 AM
steeldust's Avatar
steeldust
ignition ground?
i have a 78 f250 4x4 400cid .the ground for the secondary ign. is in the distributor,right? should there be a screw or something for it? i was looking at mine and all i can see is just an eyelet but its not screwed down or anything,just kinda sitting on the dist base. the 3 wires come from the ign box, the ground stops at the distributor at the rubber grommeta dn i guess the ground connection is in this grommet? it doenst look right to me but...? if someone could tell me what its supposed to look like that would be great.
oh i should add: if the ground is suspect,would the ign not work at all or not properly or cut out once in a while kinda of thing. if i think the ground is nfg,could i ground this somewhere else or does it have to be in the distributor
thanx for the help
Old Apr 30, 2004 | 01:00 PM
rebocardo's Avatar
rebocardo
Usually, the ground wire is attached
1) under the screw that holds down the points
or
2) on the plate that the points are attached to
or
3) under the screw for the condensor.
It would cut out and not work properly. Probably would work, since the dist. is grounded to the engine.
Here are a few pictures of distributors
See the ground wire on the left?
Old Apr 30, 2004 | 01:03 PM
rebocardo's Avatar
rebocardo
and how the positive is attached to the points and condensor?
Another picture
See how the (-) comes from the coil into the dist. and attaches to the plate?
Hope this helps.
Pictures courtesy of Mitchell Automechanics ISBN# 0-13-586124-1
Old Apr 30, 2004 | 02:10 PM
steeldust's Avatar
steeldust
hi again. thanx for the help. i guess i should have said its an electronic ign. sorry abiout that. but i guess the idea for the ground would be the same right? thanx again- good diagrams.
