Anybody install the Oil Guard filtration system yet. I just rec'vd mine last night and will be installing it this weekend. I noticed I did not receive the mounting bolts to install the unit on the chassis, it that normal, if so what size bolts do I need to buy? Also how much make up oil do I need to add after the install? Any info would be greatly appreciated.
The way I have my Oil Guard positioned and hoses routed adds a little over a quart to the system.
When changing the oil, I pull the plug on the oil pan, then remove the stock filter. Then I move the drain pan underneath the Oil Guard housing, slowly unscrew and let it drain. Not messy at all on horizontal mounting.
I decided to mount it horizontally in the frame rail to provide maximum ground clearance and protect the hoses and assembly from any potential clearance issues.
