Forgot to ask my installer what PSI they had put in my tires back in january. Im running 285/75/16 BFG MT's on a '03 F250, what PSI should i keep them front and rear?
Thanks
-bigdawg
Look on driver's door frame, sticker with VIN will also show recommended PSI for daily driving.
PSI shown on tire is, like it says on tire also, MAX PSI for MAX loaded vehicle.
Not usually required to run max PSI unless you are actually loading the vehicle down or doing some major towing.
I've got 295/75 BFG's...I run 55 front and 45 rear. Tire contact patch is about 1/8" from being all the way to the edge, just about perfect in my book. BTW, I run unloaded 90% of the time, when I am loaded, the rears get the max on the sidewall of my BFG's.
Remember too that the door sticker is for the stock tires and would not necisarily apply to aftermarket tires that have a different load range or different max pressure. I run 60 front 50 rear in my BFG at 305/70's.
