need help
Old Apr 29, 2004 | 01:08 PM
greenterror's Avatar
greenterror
Question need help
im getting no power to my a/c unit on the serpentine belt.i spliced the wire to tie into my electric fan,so i replaced the a/c clutch diode still not working. i cant find out why im getting no power to it any help is appreciated
Old Apr 29, 2004 | 05:45 PM
TNTsF-250's Avatar
TNTsF-250
I know you've done this already, but 1st. check you fuse (30 amp) i didnt catch your year ? anyway check your lowside pressure switch unplug it and jump it over ,see if the comp.clutch turns over ,check your wires to , for cuts or even unpluged. diode in the clutch ? most if its a reman clutch assy, come as a set a/c clutch,feild,& pully . good luck
