Sponsored by: Real Truck
rear diff gasket & oil ???
Old Apr 29, 2004 | 01:07 AM
Badford's Avatar
Badford
Question rear diff gasket & oil ???
ok, i got a new chrome rear diff cover, can i get a new gasket from ford or is it silicone? also whats the best oil to get. im looking @ some royal purple 75/90 i think.
thanks
Tony
Old Apr 29, 2004 | 07:32 AM
FortyFords's Avatar
FortyFords
Use silcone gasket maker ,and you better chk the tag on the rear diff for lube reqirments.also if its a ls /unit in there you need friction modifier to add to the lube.
Rich
Old Apr 29, 2004 | 08:37 AM
99f350sd's Avatar
99f350sd
I would get a gasket also. Randy's ring and pinion will send you one...dealer no
Old Apr 29, 2004 | 11:47 AM
jetjock16's Avatar
jetjock16
99 whats up.. i havent posted on this board in over a month.. hows it been going.... anyway heres my experiance... i would rather have a gasket.. thats my OPINION.. however i did get a gasket when i ordered and installed new gears... and it had a slow leak.... the other 20 times ive re-sealed up my rear end with gasket maker.. it never leaked?
Old Apr 29, 2004 | 05:01 PM
99f350sd's Avatar
99f350sd
I havn't been around much either..you have to use the" right stuff" gasket maker also I'm told.
JJ I've got the bed off my truck I'm rust proofing the frame and everything...I'll send you pic's
Dick
Old Apr 30, 2004 | 07:02 AM
V10man's Avatar
V10man
There is no gasket. Use sealer. Royal Purple is OK, no additive needed but you need the 85w140 weight.
Old May 1, 2004 | 08:23 AM
cwb's Avatar
cwb
There are plenty of gaskets but none of them work very well. You will still need the friction modifier with royal purple. Only Amsoil eliminates the need for fm.
