79+ 460 Flywheel
Old Apr 28, 2004 | 08:45 PM
IAM.CA's Avatar
IAM.CA
79+ 460 Flywheel
I'm swapping in a 79 460 into a 78 F-150, mating up to a NP435. I ordered a 12" clutch, knowing that I could get a flywheel from Centerforce if I couldn't find a used one locally. I checked the centerforce site yesterday, and the flywheel for the 12" clutch is no longer listed. So, I'm wondering if the centerforce, or anyother flywheels are drilled with dual patterns to accept a 12" clutch. I searched yesterday, found out that 390 flywheels are, but those being internally balanced won't help much. So, I guess to sum this up, is the stock 460 flywheels drilled to accept a 12" clutch, or am I going to have to find one that is/get one machined for it to fit? Thanks.
Old Apr 29, 2004 | 02:51 AM
Superdave's Avatar
Superdave
Don't know about the 12" clutch issue.
Have you looked on ebaymotors for a flywheel that may work for you?
