i will be getting a set of rims from a local junkyard.my truck is 2x4 and i will be getting 3 from a 2x4p/u and the 4th is on a 4x4 will the pattern be the same or are they different?
ok i just asked a friend here in the city and he said the center hole is bigger in the 4x4 rim to acomodate the different size hubs and he said he is pretty sure that the lug pattern is spaced differently too...i hope he is wrong about the different spacing of the lug holes...
any help from a knowledgeable source is much appreciated at this point...
F150's should all be 5 on 5.5". That is for 80-96 and possibly older. The '97 up have 5 on 139mm if I'm not mistaken.
natewoz, 97-03 and 04 Heritage are 5X135. New 04s are 6X135. Also the 5X5.5" does go back farther than 80. I am not sure how far back, but could be quite a ways.
thanks in advance,dave in n.y.
The center hole may be bigger, I am not sure. The lug spacing is the same.
Ford79, thanks for the info. My first truck was a 78, and it had the 5.5" pattern.
thanks for the info...kingfish,it was of much help to me now all i need is to go get them...it might take me a few days seeing as how i only have 30mins between opening time and when i have to clean up and get ready for work each mornin to go try and get them from the salvage yard but i will get them...
wish me luck with the new tires/rims/and alignment to come very soon
