Computer Chips & Tuners
Odometer Message
Old Apr 28, 2004 | 04:10 PM
mvlr5000's Avatar
mvlr5000
Odometer Message
Anybody knows what means the follow message that appears on LCD display on my cluster?
When I push the RESET button it appears E 08 6,
I push it again and then appears 1053 CAL.
Thanks for any aid .
Mario Lobato
Aerostar 1993 4.0 Lt
Old Apr 29, 2004 | 07:32 AM
ssn randy's Avatar
ssn randy
The "E" means english version for MPH not kilometers, not sure about 08, 6 means that there are 6 resets left and that the factory has not adjusted or recalibrated the cluster. the 92-96 f150's were able to reprogram the cluster 6 times for different reasons, you have all 6 remaining. the 1053 cal is for tire size. you can change this to a different number based on tire size so your speedo reads the correct MPH. For more info on this look above in the tech section on speedo calibration/adjustments, its a good article.
Old Apr 29, 2004 | 11:51 AM
mvlr5000's Avatar
mvlr5000
Thanks a lot ssn randy
Right now I am going to read the article that you recommend to me.
Thanks again.
