Fuel Filter?
Old Apr 28, 2004 | 11:35 AM
82StepEffie's Avatar
82StepEffie
Fuel Filter?
Where is the fuel filter on a 1982 300cid with a 1bbl? And how do you change it?
At about 60mhp the truck feels like it is choking, and running out of gas. If I push the gas pedal it makes it worse. It has happened at slower speeds, but is prevalent at highway speed. I think it is the gas filter not letting enough through to the carb.
Patrick
Old Apr 28, 2004 | 05:25 PM
nickmobile67's Avatar
nickmobile67
On my 86 flareside with efi 302 it is on the inside of the frame rail, just about under the driver's floor. With a 300, it shouldn't be too hard to follow the fuel line back to it.
Old Apr 28, 2004 | 05:30 PM
TowinBob's Avatar
TowinBob
It should screw right in to the carb with the fuel line screwing into it.
Old Apr 29, 2004 | 10:01 AM
82StepEffie
Is it under presure? any tips to replacing one without bathing the engine in gas?
Old Apr 29, 2004 | 10:22 AM
Fordtech1's Avatar
Fordtech1
Should only have pressure on it when the engine is running. Not much fuel spillage after sitting a while, couple of rags under filter should do. This thing is small!
