trans and diff work
Old Apr 28, 2004 | 10:53 AM
yoda's Avatar
yoda
trans and diff work
this wheekend Im going to change the trans oil too mobil ATF and
I want to add new diff Covers and need to know 1.is a dana 44 cover the
same as a dana 44IFS cover 2.who makes the bast diff covers
3. where is the fill plug on the trany and that's it.
Old Apr 28, 2004 | 02:54 PM
95f150's Avatar
95f150
Whats your truck? Auto or manual, if manual your fill plug should be on the side of the tranny. fill it up until it starts to leak out of the filler hole. Park on a level surface. What truck you got? IFS or solid axle? If its 80 - 96 and nothings been done to your axle in your f150 you have the ifs, buy an offroad mag, you will see those diff covers in there.
Old Apr 28, 2004 | 04:47 PM
MeBadDog2002's Avatar
MeBadDog2002
The Dana 44 ifs does not have a front cover. You have to pull the axle shafts and remove the diff.
Old Apr 28, 2004 | 06:24 PM
yoda's Avatar
yoda
O DA#* sry 1995 f150 5speed 4X4
Old Apr 28, 2004 | 06:57 PM
oldhalftons's Avatar
oldhalftons
The drivers side axle beam is cover on the TTB dana44.
The differential housing bolts into it.
