Modular V10 (6.8l)
Sparkplug question
Old Apr 27, 2004 | 08:56 PM
HeavyAssault's Avatar
HeavyAssault
Sparkplug question
I have heard of plugs referenced by a "hotter plug" or "colder plug". I believe they are refering to the operating temperature of the plug. Am I correct??
Can someone please help me understand this??
Old Apr 28, 2004 | 05:06 AM
Monsta's Avatar
Monsta
Sit. Stay.
Yes, you are correct.
Sparkplugs come in varying heat ranges. This way a plug can be matched to the type of use the engine will be receiving.
For low speed, short hop and extended highway driving, the plug's electrodes must stay hot enough to burn away carbon deposits, so a hot plug is needed.
For high speed racing at high rpm, a hot plug can glow like a diesel glowplug causing pre-ignition and detonation. To prevent this a cold heat range plug is needed. But in low speed driving, a cold plug can become fouled with carbon.
A plug's heat range is determined by the length of the insulator of the center electrode.
If the porcelain insulator is short, it is a cold plug. A cold plug's short center electrode has a short path to conduct heat out of the electrode.
If it is long and extends deeply into the steel shell of the plug, it is a hot plug.
A hotter plug has a longer path and dissipates heat more slowly.
Factory sparkplugs typically split the difference and are usually equipped with a plug that split the heat range right "down the middle".
mrsvegan
17
Oct 19, 2013 07:26 PM
jspringator
Modular V10 (6.8l)
Oct 19, 2013 08:50 AM
bookum1
Modular V10 (6.8l)
Dec 6, 2007 09:21 PM
stevelacey75
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 12, 2004 08:29 PM
millbobs
Mar 30, 2001 06:26 PM
