Paint Problem
Old Apr 27, 2004 | 08:38 PM
Sore Knuckles's Avatar
Sore Knuckles
Paint Problem
Painted my cab this afternoon. Red, acrylic enamel with hardner. I ended up with 3 small spots on one cab corner right behind the passenger door (not a real obvious area) where it appears the paint simply didn't adhere properly. Not sure where to go from here. I was hoping that I might be able to sand them out tommorrow afternoon (400-660 grit?) wipe down, and maybe use a touch up gun to blend back in. If that would work, how about the overspray I get on the areas that aren't sanded? Will that cause me a problem? Will it have a "frosted" appearance. Any advice would be deeply appreciated!!
Old Apr 27, 2004 | 09:07 PM
stevef100s's Avatar
stevef100s
It depends on a lot of factors, whether you can get it to blend in. I'm not a pro, so sometimes I'm successful and sometimes not. Try keeping the fan shape as small as possible. If not, the outer edge of your fan will appear dry. Sounds like you had some spots with silicone on them. Try adding a capfull of fisheye eliminator per quart of paint to cure that problem. Only thing is, that once you use fisheye eliminator, every coat after that on the same vehicle has to contain it also. Maybe you can just wipe it down with grease and wax remover, but I've had spots on vehicles that just would not take paint without the additive.
Old Apr 28, 2004 | 12:13 PM
Sore Knuckles
Thanks Steve...I believe once I sand it out it will cover okay...reducing the fan shape is good advice...I hadn't thought of that.
