converter lock up
Old Apr 27, 2004 | 06:42 PM
bigpowerstroke's Avatar
bigpowerstroke
converter lock up
When they say that the converter will lock up what does that mean? What does the truck do when it is locked up? Also, I have seen an upgrade for converter lock up, How will this upgrade help out the truck?
Old Apr 27, 2004 | 10:06 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Inside the torque convertor of a 'lock-up' convertor, there is actually a hydraulically controlled clutch that locks the engine to the transmission input shaft (much like a manual transmission) thus eliminating most of the slippage in a normal torque convertor. The reason for the clutch and lockup is: One, to reduce transmission temperature while cruising. When the torque convertor 'slips', it is actually pressurizing ATF and forcing it against the stator and driven half of the convertor. This is where 95% of tranny heat comes from. Eliminating the 'slip' effectively significantly reduces trans fluid temps. Two, Eliminating the 'slippage' by providing a direct driving link to the transmission reduces engine RPM by about 250-300 RPM at a cruise thereby increasing fuel economy.
Cody
Oops....
Upgrades for convertor lockup will cause lockup in two or three gears (second, third, as well as fourth) at steady speeds and light throttle which lowers tranny temps.
Old Apr 27, 2004 | 11:47 PM
tlbranth's Avatar
tlbranth
cleatus12r - where does a person get such an upgrade and what would it cost? My truck's a '96 w/e4od transmission. Is an upgrade available for it?
Thanks for the info
Old Apr 28, 2004 | 12:06 AM
johnsdiesel's Avatar
johnsdiesel
Diesel Injection Service sells them for about $300. Here's a link:
http://www.dieselpage.com/bdebf.htm
Banks also sells one but they don't list the price. I checked MotorHaven and they don't sell any.
Old Apr 28, 2004 | 05:59 AM
red4x4's Avatar
red4x4
Is that the Transcommand?
Old Apr 28, 2004 | 08:12 AM
johnsdiesel
It's the Banks SmartLock Trans Brake.
Old Apr 28, 2004 | 08:38 AM
red4x4's Avatar
red4x4
Doesn't the Transcommand lock up the converter also?
Old May 2, 2004 | 08:00 AM
red4x4's Avatar
red4x4
Anyone know?
Which is the best automatic device to lock and unlock the converter?
