Aerostar Ford Aerostar
Locking lugs with missing Key
Old Apr 27, 2004 | 06:33 PM
napfam5's Avatar
napfam5
I recently bought a used 94 ford aerostar. It came with with Spectrum 2000 205-65-16 inch fan wheels. Well unfortunately the wheels have locking lugs which I just noticed today and the special key is missing. And of course the previous owner can't find it. Does anyone have any idea how to get them off. Do garages have the capabilities of taking them off?
Old Apr 27, 2004 | 06:53 PM
BarryFS's Avatar
BarryFS
The last time my Aerostar was brought back to town on a low loader, just 11 days ago, the chap said he could get them wheels off. So a tower might be able to do it.
Old Apr 28, 2004 | 02:44 AM
xlt4wd90's Avatar
xlt4wd90
The typical McGuard puzzle lock has a limited number of patterns, you can try to buy a set that's real close, and then carefully grind the key until it fits. Then carefully loosen the nuts. It only has to work 4 times. Then you can send the number on the package to McGuard to get a replacement key and use the new set of lock nuts.
Yes, I've had to do this once.
Old Apr 28, 2004 | 02:56 AM
OldSkoolRacer's Avatar
OldSkoolRacer
I had the same thing happen to me with my Bronco. Most tire and wheel places have a special impact tool to take them off. Then you can get a new set or just go for regular nuts.
Old Apr 28, 2004 | 08:45 AM
x.l.r.8's Avatar
x.l.r.8
if they are the 3/4 pin type you only need 1 pin, I have made one before by chopping out the all bar one pin, this is of course if the previous owner didn't go mad tightening them up.
Old Apr 28, 2004 | 11:44 AM
jasonbbq's Avatar
jasonbbq
I've had luck with wrapping the lug with electrical tape and using a GOOD sharp pair of vice-grip pliers. The tape gives just a little extra holding power. Using a dremel to etch slots for the pliers to grab will work too. Good Luck
