How real is this where dirty shop rags have been known to combust when in the garbage.
I work in a large shop (aircraft maintenance) and we have lots of oily and greasy rags in garbage cans till the cans get full. Same as at home, last night i greased the truck and thought about the these rags in the garbage.
What conditions set up spontanious combustion, and how common is it.
I may be wrong here, but I think you have to have some sort of organic solvent/agent. Something like denatured alcohol or linseed (rapeseed) oil. I think even vegetable oil like the kind you cook with. I'm sure if I'm wrong, someone else here can straighten me and this out.
Yes greasy rags can combust easily. And then again not, depends if they get any heat going then it can. I have seen large piles of paint dust not combust after sitting for days. I've seen small piles combust less than 10 minutes after being swept in a pile. I've seen wet wood chips go and a bunk of OSB smolder for awhile at work and it was wet. Basically if it is in a closed metal container then if it does combust it will be contained.
This is a good reason to dispose of rags in a metal container with a tight fitting lid. If they do go "POOF", they will soon use up the available oxygen and go out.
