Oil & Lubrication
Not sure what to use...
Old Apr 27, 2004 | 08:53 AM
99FordRangerNC's Avatar
99FordRangerNC
I have a 99 Ranger 3.0 and I'm stuck between using the castrol mercon V and the valvoline maxlife dextron III/mercon. The truck has 78000 miles on it and its been 42000 since the last transmission drain/refill. Any opinions on this matter would be greatly appreciated.
Old Apr 27, 2004 | 09:48 AM
Casey's Avatar
Casey
The Valvoline has a MERCON rating which is the wrong one for your transmission. I'd use the Castrol MERCON V because that is what your transmission requires.
Old Apr 27, 2004 | 09:49 AM
cmlind's Avatar
cmlind
Use the recommended fluid which I think is Mercon V. Mercon is not recomended and should not be used as a replacement for mercon V. You may have shudder problems with the mercon/dexron.
