Window will not roll up!!!
Old Apr 26, 2004 | 07:58 PM
pauls99expedition's Avatar
pauls99expedition
Question Window will not roll up!!!
Earlyer today my front drivers side window will not roll up. With the truck off, when i try to roll the window up i hear a clicking noise near the fuse panel. I cant check to see if the fuse is burnt out, because i aint got no owners manuel. If anyone has any advise, i could deffently use it.
thanks Paul White
Old Apr 26, 2004 | 08:05 PM
Traxxis's Avatar
Traxxis
I would just go through all the fuses and check them, I mean, it can't hurt.
Welcome to FTE
Stan
P.S. You might want to post this in the Expedition forum.
Old Apr 26, 2004 | 10:03 PM
pauls99expedition
Question Tried all of the fuses!!!
I tried all of the fuses. They all looked fine and clean. I then checked the relays and noticed that the second relay from the top is very hot. I clicked the down button and i could hear a clicking from the relay. When i press up on the window i do not hear anything in the fuse box. again this is a 99 expedition 5.4 liter. I took the relay out and NO power windows work. I do not have an owners man. so i cant tell the fuse layout. Is is possible that the relay is bad? or is the fuse circut bad?
thanks again,
Paul White
Old Apr 26, 2004 | 11:41 PM
MisterCMK's Avatar
MisterCMK
Since you hear the relay clicking, I would think that your power window motor has gone out.
maineflyer
1997 - 2003 F150
Apr 1, 2012 08:43 PM
85MD
2004 - 2008 F150
Oct 8, 2010 06:53 PM
rhondafrank
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jun 22, 2009 09:23 AM
tomcasino
Minnesota Chapter
60
Mar 19, 2006 07:30 PM
