1978 - 1996 Big Bronco
This doesn't look good
Old Apr 26, 2004 | 07:52 PM
threefiftyone's Avatar
threefiftyone
Exclamation This doesn't look good
I just noticed today that I have some oil draining out from under my airbox. As I removed the cover, I noticed that the air filter was unusually brown in one spot. I took it out and right where the breather filter is (in the side of the box), there was oil everywhere. The breather is soaked, and the airbox is soaked. I put new air and breather filters in about six weeks ago. Has this happened to anyone?
'92 Bronc
351
E4OD
Old Apr 26, 2004 | 08:39 PM
JBronco's Avatar
JBronco
Yes, this has happened to many, many people.
It's either a bad PCV valve, or else your engine is worn and producuing excessive blowby.
Replace the PCV valve. If it still does it, unfortunately you are looking at a rebuild, actually only a ring job but at this point the motor is worn and should be rebuilt.
Old Apr 26, 2004 | 09:13 PM
dyarumian's Avatar
dyarumian
pull out the pcv valve, and see if it is sucking by putting your thumb over it (with the engine running), if its not, try cleaning it out, if that doesnt do it get a new one. also see how much pressure is comming out of the hole in the valve cover. if theres a whole bunch its time for a ring job and everything that goes along with that
Old Apr 26, 2004 | 09:15 PM
threefiftyone
Awesome
I'll check that PCV, thanks
