Gutting the EBPV
Old Apr 26, 2004 | 06:55 PM
Fire Rooster's Avatar
Fire Rooster
Gutting the EBPV
Any one know about this mod? What does it do ? Does it hurt the truck? Does it help the performance? Give me some info please.
Thanks Guys
Fire Rooster
Old Apr 26, 2004 | 07:01 PM
johnsdiesel's Avatar
johnsdiesel
You remove the exhaust backpressure valve to open up the exhaust system a little more. It helps performance a little from what I've heard and won't effect the truck. The only downside is that when it's cold you won't have it there to help warm up the truck, but you live in AZ so you don't need it.
Old Apr 26, 2004 | 07:06 PM
TJC1989's Avatar
TJC1989
Thanks Guys
Fire Rooster
It won't hurt it. But you will burn the bridge behind you for winter warm ups. But as stated since you live where its warm, may not matter very much. Before you do, have you considered just disconnecting it? As I understand it, disconnecting the two wire harness under the turbo pedestal laeves it in wide open mode.
Old Apr 26, 2004 | 07:07 PM
Fire Rooster
Thanks john,
Have you done this mod? If so what about the trips up north where it does get cold? Does it just take a little longer to warm up? How about tow performance Does it affect it? Better worse? Does it lower my EGT's
Fire rooster
Old Apr 26, 2004 | 07:08 PM
johnsdiesel
TJC1989, the purpose of this mod is to remove the little bit of restriction that is there even when the valve is open.
Old Apr 26, 2004 | 08:20 PM
jadel's Avatar
jadel
does this valve cause the engine to have not much power or to feel boggy when cold.
Old Apr 26, 2004 | 08:27 PM
johnsdiesel
jadel, yes, that's a result of this valve being closed.
Fire Rooster, no I haven't done this mod. I've only lived in TX for less than 1 year, moving here from CT. I'm not sure how long I'm going to be living in warm weather so I'm going to leave mine in place.
Old Apr 26, 2004 | 08:31 PM
Fire Rooster
John,
Thanks for your response again. I am still on the fence about this mod. More research needed.
Fire rooster
Old Apr 26, 2004 | 09:43 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
There is no down side to gutting the EBV, the engine will warm up the same as it always has, the EGT's will go down, and the potential will be there for the turbo to spool up a little better.
It's kind of the same deal as removing the Intake Air Heater, and rerouting the CCV, it dosen't neccessarily add any power, but by clearing the intake and exhaust of all possible restrictions you open up the door.
