diesel turns off
Old Aug 21, 2002 | 03:38 PM
glafond's Avatar
glafond
diesel turns off
[updated:LAST EDITED ON 21-Aug-02 AT 05:32 PM (EST)]i have a '96 f350, had it all it's life.
at about 115000 miles it developed a problem.
at idle or full speed it just turns off.
everything electrical is still on. i.e. radio, fan, gauges.
when i'm running down the road it will usually re-start on
it's own. when i'm idling, i have to re-start it.
anybody seen this?
it isn't associated with either fuel tank, empty or full.
i've replaced the fuel/water filter
i've wiggled everthing i can find and can't make it quit.
just happens once or twice a day.
extremely frustrating.
ok, it looks like it is the cps.
anybody know where the engine serial number is located?
thanks for the help
Old Aug 21, 2002 | 03:46 PM
basstardo's Avatar
basstardo
diesel turns off
it sound like your cam position sensor is going out. do a search on this board for CPS and you should find plenty of information.
basstardo
Old Aug 21, 2002 | 04:43 PM
glafond's Avatar
glafond
diesel turns off
thanks, i found the cps, and by the info on this board it appears to be a common problem.
you wouldn't happen to know where the engine serial number is located would you?
Old Aug 21, 2002 | 06:48 PM
The Diesel Dude's Avatar
The Diesel Dude
diesel turns off
There should be a label toward the front of the drivers side valve cover with the serial number on it. If the label is gone it is on the pad that mounts the rear portion of the oil cooler to the block (stamped into the block above the oil filter).
Old Aug 22, 2002 | 12:07 AM
Brian460's Avatar
Brian460
diesel turns off
That is exactly what my friends 97 F-250 did. We replaced the cam sensor and cured the problem.
Brian
Old Aug 23, 2002 | 01:15 PM
glafond's Avatar
glafond
diesel turns off
