Electrical problem/Battery
Old Apr 24, 2004 | 05:44 AM
stallyngrl's Avatar
stallyngrl
Question Need a wiring diagram for my 1974 F-250 4 x 4
I am having problems with my 390's electrical system, ok laugh if you must, but my battery is dead constantly. Yes I did buy a top-of-the-line new battery, but still I have a dead short somewhere or perhaps some wire isn't hooked up correctly ... I am hoping that I can find a schematic to compare my wiring set-up against... Any ideas??? Thanks for any help...
Stallyngrl
<!Boy do I like Fords.... 2- F-250 3/4 ton 1966's, 1- F-250 1974 4 x 4, 1- F-100>
<!1964 flatbed 4 x 4 ( for sale ) 1- 1986 Bronco II 4 x 4>
<! and a 1989 Crown Vic in a pear tree...>
Old Apr 24, 2004 | 08:27 AM
ashvalentine's Avatar
ashvalentine
The cheapest and quickest was is to get a haynes. The 74 diagrams are in the back.
To find the short, hook a test light up between the positive battery post and the positive battery cable. That light should be on when the key is out. If so, start pulling fuses until you find the leeching circuit. If not, replace the voltage regulator.
ash
['And then measure the voltage on the battery when it's running. Should be 13+.']
Old Apr 24, 2004 | 02:52 PM
stallyngrl's Avatar
stallyngrl
ash
Hey thank you Ash, I appreciate the suggestion I am going to check it out immediately.
Old Apr 24, 2004 | 03:19 PM
LxMan1's Avatar
LxMan1
I bad voltage regulator can charge fine, but stick closed internally and cause the battery to run down when it is not running.
Chris UK, To wire your electric choke properly, all you need to do is splice into the Stator wire coming off of the rear of the alternator. It only sends voltage to the choke when the engine is running. This is how the factory wired them.
Then you can adjust the choke properly and it should open up slowly after the truck is started.
Old Apr 26, 2004 | 05:10 AM
Amtek's Avatar
Amtek
<!Sorry to deter from the topic, but..>
<!Stallyngrl- noticed in your sig you have a 64 F-100 flatbed for sale? I was>
<!wondering if you still have it... it seems i cannot email you because i dont have 15>
<!posts yet. >
and for the battery going dead, how long after you driven the truck does the battery go dead? in other words, how long does it sit between use?
Old Apr 26, 2004 | 12:58 PM
dfisher1's Avatar
dfisher1
Chris,
Did you ever get the choke to work? I'm assuming that's all you needed to do to get it to start cold.
Your sending unit for water temp is in the intake manifold fairly close to the thermostat.
The oil sending unit is in the back of the motor, behind the carb on the driver side.
Ground the gage wire, and it should slowly peg your gage. Once you've determined which wire is for which gage, terminate it respectively. If the gage acts crazy or doesn't work, change the sending units to gage or idiot lights, which ever you have.
Secondly, there is about a 90% chance a draining battery is a bad voltage regulator. This is located on the pasenger's inner wheel well and about the size of a coffee cup. Replace it. The other 10% chance is some modification from factory intent.
Good Luck,
KingFisher
Old Apr 26, 2004 | 01:01 PM
Mil1ion's Avatar
Mil1ion
Chris ...that UK guy was here 2 years ago ...the date of his posts.
I split the thread.
Old Apr 26, 2004 | 10:09 PM
LxMan1's Avatar
LxMan1
Gee, I missed that date too!!
