headlights
Old Apr 26, 2004 | 09:07 AM
82F100PU's Avatar
82F100PU
headlights
hi ya'll:
would someone give me a procedure, or point me to some online info, for changing a headlight on my "new" 96 150? haven't picked up a chiltons on it yet. thanks
Old Apr 26, 2004 | 10:57 AM
MustangGT221's Avatar
MustangGT221
The easiest way is to remove the battery and unbolt the coolant tank. The hose on the coolant tank is long enough to let u put it on the airbox. I put a string around it and the hood spring to hold it. There are two 10mm nuts on the back of the turn signal lenses that need to be removed. Then the two screws under the hood on the trim need to be removed. That'll allow you to pull the corner/turn signal assembly out after removing the bulbs. Then you can unscrew the adjustment screws that hold in the headlights to remove them, there are three.
Old Apr 26, 2004 | 11:31 AM
82F100PU's Avatar
82F100PU
head lights
thanks justin!
i could tell there were some hidden bolts but i could not see them.....i'm sure it won't be much to it now,,,,,
ps what is the lever that is located close to each headlight?
Old Apr 26, 2004 | 11:39 AM
MustangGT221
Lever....?
Old Apr 26, 2004 | 12:31 PM
82F100PU's Avatar
82F100PU
headlights
under the hood .... located directly above the headlights..is a "post" that extends an inch or more above the crossmember...it goes down in the direction of the headlight assy.....there is a slot that the post goes through...located below the gross member but above the headlight assy....it can be positioned either to the right or left in the slot
Old Apr 26, 2004 | 01:08 PM
MustangGT221
Does it have a small hex head on it? Thats another headlight adjustment screw.
Old Apr 26, 2004 | 07:18 PM
82F100PU's Avatar
82F100PU
headlights
perhaps i should have called it a small rod i called it a lever because it seems to be positionable in the slot i mentioned. i hope to get the headlight apart tomorrow. perhaps then i can get an idea what it might be. i'll let you know. anyway thanks for the help.
Old Apr 29, 2004 | 10:59 AM
Trail Rider II's Avatar
Trail Rider II
4mm hex socket to adjust the the lights
I just did this April 26 2004, today is the 29th.
You can also pop the clips, its a two handed job, pry out with a small flat screwdriver and pull up all at the same time.
I bought a set of clear Diamond headlights for the price of one new FOMOCO unit. Same with corner lights and clear turn signals.
Broke the rt headlamp door, $38.00 from FORD, I got one new from Midstates Aftermarket Little rock Ark for $26.00 delivered to my front door..
Old Apr 29, 2004 | 11:48 AM
82F100PU's Avatar
82F100PU
headlights
thanks trail rider 2
headlight adjusters! who woulda thunk
thanks for the source info also
fred
