Help, 302 with bad (?) idle..
Old Apr 25, 2004 | 11:47 PM
packrat56's Avatar
packrat56
I have a 302 from the early 70's in my 56 F-100, has a C4. 2 Bbl carb, stock ignition, new points, plugs, wires, cap, rotor, condenser. When I bought it I was told "it has a bit of a cam in it" I do not know if that is true or not. Had a rough idle before a tune up, still has it after all that. At an idle it sounds like a miss, the whole truck shakes, it is set at the factory specs for idle level. Runs well over all, however shakes a bit at idle. I have no experience with this engine so I am relying on you folks for a hand here. What should it "feel" like and "sound" like at an idle, and how can I smooth it out? Or should I?
Thanks..
Old Apr 26, 2004 | 12:34 AM
themoonshineboy's Avatar
themoonshineboy
You might want to look into your vacuum, it's hard to say but I would think with a 2 Bbl and an auto trans the cams not real big, but who knows. Ive got a summit cam in a 70 302 the cam runs 2000-45000 RPM that is smooth at idle. The other mods are .30 over, 10.5:1 comp, 650 holly vac sec, stelth intake, headers. One more thing to look at is the dwell of your points. When the dwell slips on my points the 302 will idle rough.
Hope this helps
Old Apr 26, 2004 | 12:37 AM
packrat56's Avatar
packrat56
The dwell is right on, tell me more about the vacuum, what am I looking for, and where? Sounds like a possibility..
Old Apr 26, 2004 | 09:16 PM
themoonshineboy
For the vacuum test you will need a vacuum gauge. warm up your motor and hook it up to a intake fiting, the reading should be around 12 to 16 at idle I think. Most gauge's have a normal scale on them. Of corse your vacuum reading will very by cam size and such. When your in there look for and hose's that might be off, cracked or lose. Also a bad carb base gasket or intake gasket could be a leaker. Dont forget the vacuum hook up at the tranny for the modulator.
Keep me posted if you like
If it's not vacuum there are some other things we can look into.
Old Apr 26, 2004 | 10:56 PM
packrat56's Avatar
packrat56
I will check it out, and I sincerely appreciate the assistance!
Old Apr 28, 2004 | 07:56 PM
themoonshineboy
No problem.
No problem. I hope it helped.
Old Apr 29, 2004 | 02:21 AM
quantalimo's Avatar
quantalimo
And if it isnt all that the carb probably is bad.........What else could it be The carb...
That what was wrong with my 75.......and I fixed everything else but that before I found out..
