Modular V10 (6.8l)
160*T-stat
Old Apr 25, 2004 | 09:54 PM
HeavyAssault's Avatar
HeavyAssault
Question 160*T-stat
Anyone running this t-stat in their truck? I have done quite a bit to the engine in the way of performance mods.
I just finished installing the 160* t-stat and I really don't understand why it has made the truck run smoother. I had a slight bit of pinging when going up hill, now just smooth acceleration.
Could it be different season gas?
Any explaination?
Old Apr 25, 2004 | 10:19 PM
jcrice's Avatar
jcrice
I'm not sure why it would run smoother, but a cooler engine is less likely to ping. I'm not exactly sure why; maybe someone here can explain...
I haven't tried Hypertech since the dissappointing results I experienced with them in the past, but they recommended running a cooler stat and (of course) higher octane fuel - those two things allow more spark advance without detonation. There's also water injection, cool cans, etc., but I digress.
Old Apr 25, 2004 | 10:29 PM
gmsux's Avatar
gmsux
The only problem with the 160 Tstat is keeping the engine cold enough to stay in cold start mode more often thus using more fuel.... Not always but it could create problems for you. Generally a very minor potential for improvement vs issues... I'd skip it and go for more proven methods of HP improvement. My .02
Old Apr 26, 2004 | 02:44 AM
Monsta's Avatar
Monsta
Sit. Stay.
"Cooler" engines have less "hot spots" in the combustion area. This helps prevent pre-ignition or detonation of the fuel.
Old Apr 26, 2004 | 08:06 AM
camo4stealth's Avatar
camo4stealth
I have installed a 165 thermostat in my v-10. After installing the headers, MAFS and throttle body, it was running lean. The lower temp stat makes the engine controls think it's cooler operating temperatures and feeds it slightly more gas. Just enough to get the job done. I have no problems with winter driving or fuel mileage going down. Just more power.
Old Apr 26, 2004 | 06:41 PM
HeavyAssault
Ok so using the electric fans I have I could raise the "on" temp a bit higher in the summer and prevent this waste of fuel.
Well now that I think about it, I have not had any codes for a lean condition when driving. The only code that has recently started popping up is "EGR insufficent flow".
raven3
Aug 6, 2014 09:00 AM
Rob Cuenin
Mar 4, 2013 06:11 AM
F-250 WARHORSE
Jul 27, 2011 01:34 AM
mblanken881
Dec 2, 2010 12:05 PM
JBronco
1978 - 1996 Big Bronco
Jan 24, 2002 08:20 PM
