How are yall
Old Apr 25, 2004 | 04:02 PM
8325092Exploder's Avatar
8325092Exploder
How are yall
Hi I am new to the site. Name is Jay and I have a couple questions for yall. I have an 83 F250 , 351 with a top loader bull low 4 speed. How much of a pain is it to convert it to hydraulic clutch from manual, only because the linkage is worn badly. How do I stop the front tires from leaning out and wearing the tread in about 2 months? Thank you
Old Apr 25, 2004 | 08:44 PM
drumlinecowboy's Avatar
drumlinecowboy
tire wise... u prob need an alignment. local atuck mechanic can help u w/ that. the tire tend to lean in mybe 5 degrees. standard issue toe i. its a 4wd thing. the clutch thing i have no clue about. i know the guy i bought my beast off of did it... but he is the best mechanic in my area, so it can be done.
Old Apr 26, 2004 | 02:06 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Your front springs are wore out or else all your bushings are in your TTB which since it all piviots off the middle the middle sags lower. Clutch could take some work, but can be done, you will need the whole peddla assembly and master cyl from an 86 of something then a hyd. slave, but I'm no tsure if that slave will go with your mechanical bellhousing.
Old Apr 26, 2004 | 05:03 AM
8325092Exploder
thanks alot, I was told that it was the rear springs that were shot. The clutch I will just send out to get done, Im just to lazy to screw with it
