not enough oil
Old Apr 25, 2004 | 09:43 AM
drive shaft's Avatar
drive shaft
Question not enough oil
built 460 motor last year for twd truck pulling, made 3 passes and no 8 cyc rod came out block, bearings were spent, built another this winter just made my 3 pull lost oil pressure which was 70 plus down to 20, tore bottom down no 8 cyc bearings were into the copper, all the rest were ok, using a melling oil hvp, has any one had this problem or might have a solution for this one seems like it is at the back of the motor thanks for any replys
Old Apr 25, 2004 | 10:04 AM
68torino's Avatar
68torino
Without knowing who and how the motor was rebuilt there are alot of questions. If the oil passages were not cleaned out after the hottanking and all machine work being done. There could be something plugging that oil passage. If all the oil passages were cleaned real well and the motor built well, then I would look at adding oil restrictors in the heads to keep more oil in the mains and cam bearing areas.
Old Apr 26, 2004 | 04:38 PM
edwing's Avatar
edwing
check to see if oil hole in crank is offset from the hole in the bearing. i found the one in my 460 off so far the bearing covered it almost completely
Old Apr 27, 2004 | 02:43 AM
Superdave's Avatar
Superdave
You mean the cam bearing positon in the block where the oil passage comes down to oil the main bearing?
Old May 5, 2004 | 01:31 PM
shawnlee28's Avatar
shawnlee28
heres my 2 cents the 460 short block can take around 600 ponies stock a good builder recommend oil journal and pump enlargement
