Hood liner? Is it needed?
In January I installed a FatMat hood liner in my 01 f150. Last Friday I removed it because it was falling off and causing excessive heat in the engine compartment.
I was going to put the original back on but haven't done it yet- it's way too nice outside.
Will there be any negative impact if I leave the liner off? I've heard engine heat can cause paint problems but I can't imagine it's worse than when the dark blue truck sits outside on a 100 degree day.
Thanks
Tim
Thanks
Tim
Isn't it a fire resistant material so if there is a fire under the hood, the plastic retainers melt and it falls to help smother out the fire? 100 degree sun is not as hard on the paint as the 200 degrees plus that comes from under the hood. It will help keep the paint from fading over the years.
vze2sgxa
Escape & Escape Hybrid
02-18-2011 09:29 AM
Gt-358
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
02-03-2005 06:09 PM
