Engine Identification & Update
Old Apr 24, 2004 | 05:01 PM
mudracin_1's Avatar
mudracin_1
I would like to know what model of 351 came in the 1979 Thunderbird and is it possible to put it in my 77 F-150.thanx
Old Apr 24, 2004 | 06:31 PM
cannonfodder's Avatar
cannonfodder
Smile
That would be the old boat anchor 351 m Yes it will fit IMHO Around here those are known as the worst engine Ford ever built
Last edited by cannonfodder; Apr 24, 2004 at 06:34 PM. Reason: That should start something
Old Apr 24, 2004 | 09:26 PM
LxMan1's Avatar
LxMan1
It could be a Windsor too. You will need to count the valvecover bolts. Also, the 351W has the thermostat housing on the front of the intake manifold. The 351M has it on the block just above the waterpump.
Old Apr 25, 2004 | 11:10 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check the engine ID FAQ in the sticky at the top of the forum.
Old Apr 25, 2004 | 04:59 PM
ranger429's Avatar
ranger429
6 valve cover bolts = W
8 valve cover bolt's = M
Old Apr 26, 2004 | 01:49 AM
tude's Avatar
tude
exhoust manifolds /header bolts work to windser were level side to side and 351m/400 are at an angle off the to of my head i dont remember witch way but at an angle ........ and in my 78 tbird 351m ....... in my 79 cougar 351w ...in the cougar i know they didnt have modifides just 302s and 351ws
Old Apr 26, 2004 | 08:00 PM
mudracin_1's Avatar
mudracin_1
now will it fit?
Ok i figured out that its a 351W that came outa that 79 Tbird and was just making sure that it will go in my 77 150 and bolt up to the tranny and everything.thanx alot for any help.
Old Apr 26, 2004 | 10:07 PM
LxMan1's Avatar
LxMan1
What engine do you have now? 302- yes, 351M- no
If a 302, you will need to run the 351W accessory brackets out f the car since the block is taller and wider than the 302.
Old Apr 26, 2004 | 10:23 PM
mudracin_1's Avatar
mudracin_1
i have the 351M,what am i going to do?
Old Apr 27, 2004 | 02:00 AM
ashvalentine's Avatar
ashvalentine
What ARE you going to do? I don't know what you're trying to do.
If you just WANT the Windsor, you'll have to change out the transmission/bellhousing, depending on how you want to setup, exactly.
However, if you want to keep the C6, and all that, and just want to fix the engine, then sell the Windsor and get a rebuilt or something since that's going to be more cost-effective.
(New 351M/400 (460?) 600-1000$. Windsor plus new transmission plus extra engine goodies plus possible transmission/driveshaft mods and such: 1500$ on up.)
ash
['Very roughly speaking.']
Old Apr 28, 2004 | 03:08 PM
mudracin_1's Avatar
mudracin_1
Thanks for all the help, i will have to figure something different out
Old May 17, 2004 | 04:26 PM
myddad's Avatar
myddad
Smile 351 windsor
the 351 windsor bolts up fine to a c6
just did one this weekend
only problem so far is finding a crossover pipe.
it had a 302.
Old May 17, 2004 | 06:57 PM
LxMan1's Avatar
LxMan1
The 351W and 302 have the same bellhousing patterns. The 351M/400 uses the 429/460 bellhousing pattern. That's why it bolted up perfectly.
Old May 17, 2004 | 10:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
Remember that even if an upgraded engine bolts to a transmission you may have transmission problems down the line. The increased HP and torque may burn out the transmission. They may not shift properly either.
Old May 18, 2004 | 12:27 AM
scroob's Avatar
scroob
"Around here those are known as the worst engine Ford ever built "
Why do people (especially new users) post these kinds of comments in these forums? All they are doing is advertising exactly how much they DON'T know.
