79 bed pan
Old Apr 24, 2004 | 02:55 PM
nucleartruck's Avatar
nucleartruck
79 bed pan
I need to replace the bed pan in my 79 f250. I noticed replacement metal is approx 4x8. Can I get this material from another year truck. Will the bed pan from an 80's model be used on my 79?
Old Apr 24, 2004 | 03:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
Some guys use a 4x8 sheet of treadplate. Other than that you could use some used material from the local hospital... -Oooops, wrong kind of bedpan
Old Apr 24, 2004 | 05:07 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I belive the pans are the same, when I did mine I found it a lot Cheaper to get a sheet of 1/8" steel (didn't just plate over either...air chisle old floor off, make and replace bad cross members)...
Old Apr 27, 2004 | 01:23 PM
nucleartruck
air-chisel?
How well did the air chisel work? Was it able to excise the 4x8 section leaving the remaining floor intact?
