pcv question
Old Apr 24, 2004 | 02:27 PM
1979ford's Avatar
1979ford
pcv question
I have a 1979 F-150 with a 351M and a 4 speed, I need to know where to hook up my pcv valve out of the rocker arm cover. Thanks
Old Apr 24, 2004 | 02:30 PM
Mil1ion's Avatar
Mil1ion
Passenger side at the back .
This thread will be moved to the 351M/400 engine forum
Old Apr 24, 2004 | 02:42 PM
Ecuri's Avatar
Ecuri
I think what you are asking is where to hook the other end?
There should be a rather larger size dedicated port near the back of the carb that dumps into the plenum. This port is intergral with, say an AFB. Stock, I am not sure, I haven't had a stock intake since Reagan, but it should be near the carb base.
See also: https://www.ford-trucks.com/forums/s...ad.php?t=71420
(Typically, the PCV Valve is with the filler cap on driver's side, BTW)
Old Apr 28, 2004 | 06:57 AM
Dreampiper's Avatar
Dreampiper
Rear drivers side, there should be a tube approx 3/8" dia right by the mounting bolt sticking out to the rear. The tube can come out, in which case you will have a hole there.
