Computer Chips & Tuners
Predator Tuner with 02 E-350 PSD Van
Old Apr 24, 2004 | 06:28 AM
skidoo68's Avatar
skidoo68
Newbie here.What an awesome site.Found a new home.Anyways i have a 02 E-350 PSD Van.Just purchased the Diablo tuner for it.When i load a tune and drive,as soon as the tranny shifts out of first my overdrive off light flashes.This is the light on the shifter column that also has a button to disengage the overdrive.Does this in tow,40 and 60 tune.Is this normal and ok to drive still?I retuned to stock until i find some info out.I used the code reader and retreived a tranny code when the tune was in use.It was something like a live RAM memory code,should of wrote it down before clearing it.If it helps with theexact code number and wording code for an answer i can quick load a tune in.Did'nt drive it long but what a differance in power.Now the Stroker is faster than my Iroc.Thanks for any info.
Old Apr 26, 2004 | 06:38 PM
skidoo68's Avatar
skidoo68
Opps i typed in a error on my original post.I receive NO trouble codes with any of the tunes i loaded into my van.I received the code when i returned to the factory stock setting.I loaded the tow tune in again to retreive the proper trouble code i received so i can try to get some help.The code is PO603 Powertrain Control.Description is powertrain control module keep alive memory(KAM) error.Thanks.
Old Apr 26, 2004 | 07:37 PM
FTE Ken's Avatar
FTE Ken
The error is normal. It means the computer has been programmed. Clear the code and don't worry about it.
Old Apr 26, 2004 | 08:10 PM
skidoo68's Avatar
skidoo68
Thanks for the response.Do you know any info on my off light flashing on my shifter column.This is the light to show you disengaged the overdrive.Overdrive is still working i noticed when i'm using a tune but the light flashes.Also i just received a reply back from Brian at Diablo.He said to return my van back to stock tune and return the Predator for a refund.Brian said the tuner does not work on the E-series vans.He did'nt explain why i cannot use it.Wondering if you have any insight on this and reasons why?If you don't i'll mail Brian and ask.Thanks again.
Old Apr 26, 2004 | 09:06 PM
FTE Ken's Avatar
FTE Ken
Brian is right about van support. Although the Predator works with the vast majority of van applications, vans are not officially supported with it (just like the 6.0 Predator doesn't officially support 6.0Ls with earlier than October flashes but still works with most). If you can live with the light, keep it. One thing though, I suggest an EGT gauge as the vans tend to run higher EGTs than the trucks.
mudtug2
13
Jul 18, 2021 03:23 PM
jez
6.2L V8
20
Oct 14, 2017 02:59 PM
MT-F250
41
Feb 27, 2013 02:34 PM
joshofalltrades
Modular V8 (4.6L, 5.4L)
Feb 25, 2012 01:44 AM
F350Scott
May 14, 2009 07:08 PM
