Power Door Locks
Old Apr 23, 2004 | 06:00 PM
Bobshobe's Avatar
Bobshobe
Question Power Door Locks
My power door locks will not open or lock when the button is pressed. They try to, but it seems there is not enough power to complete the operation. Sometimes one door will lock and sometime one door will unlock. I can hear something (motor) running in the doors. I need help. The dealer said it woul cost over $300.00 to fix.
Thanks, Bobshobe
Old Apr 23, 2004 | 09:30 PM
Racerguy's Avatar
Racerguy
Hi Bobshobe and welcome to the forum
What year and model of truck are you working on?
It sounds like probably both your door lock actuators are shot and will need to be replaced.
Old Apr 24, 2004 | 12:22 AM
Bobshobe's Avatar
Bobshobe
Question
Its a 2000 super duty. What will it cost to replace them?
Thanks
Old Apr 24, 2004 | 08:09 AM
Racerguy's Avatar
Racerguy
I'm not sure what they cost. I just do the work and dont usually see the bill.
Your dealer probably keeps them in stock.
Old Apr 24, 2004 | 09:54 PM
Franklin2's Avatar
Franklin2
The dealer probably keeps quit a few on the shelf, if he repairs as many as I see complaints on here about them not working. I think I will get into the Ford electric door lock/window aftermarket business.
Old Apr 28, 2004 | 04:15 PM
beachbumrod's Avatar
beachbumrod
My 98 f150 truck did not come with power locks but I bought some off of ebay for 25.00 but you can get some replacement accutators at http://www.partsexpress.com for a couple of dollars. Since the existind wires are there they should be a breeze to replace. That was the hardest part of my install was running the wires to the cab. Good luck
Old Apr 29, 2004 | 07:27 AM
ptdank's Avatar
ptdank
I have a similar problem. Only it seems isolated to my drivers side front door only. Yesterday when it didn't unlock all the way I stuck the key in to unlock it and it sounded like something broke when I turned the key. Now I am unable to lock that door. I can't even force the lock down. Does this sound like the same problem?
Old Apr 29, 2004 | 12:12 PM
Bobshobe's Avatar
Bobshobe
Question
No, mine attempts to lock and unlock, it appears that there is not enough power to complete the cycle. How do yo take off the door panels to replace actulators?
Old Apr 29, 2004 | 12:56 PM
beachbumrod
Here is a link http://www.a1electric.com/installations.htm there is a f150 there this applies to power windows but it gives the instructions for removal of the door panels. All you really need is a small screwdriver and another few basic tools.
Old Apr 29, 2004 | 05:15 PM
Bobshobe's Avatar
Bobshobe
Thanks, that should be a big help.
Old May 6, 2004 | 12:03 PM
ffmbiggs's Avatar
ffmbiggs
Check out this Thread
http://www.fordtrucks.com/forums/sho...hreadid=108311
http://www.fordtrucks.com/forums/sho...ight=ffmbiggs+
Check out these treads and that should help you with replacing them. They ran about $35 to $40 for each one. I just had to replace both of mine about a month ago. I had both actuators fail at the same time with the same problems.
Hope that helps you bob
Old May 6, 2004 | 12:54 PM
Bobshobe's Avatar
Bobshobe
Thanks, Did you use atuators from ford? They qouted me $48.99 each.
Old May 6, 2004 | 03:29 PM
ffmbiggs's Avatar
ffmbiggs
Actuators
Yeah i ended up calling about 7 differtent dealers in town to get the best price. They ranged I think from $35 (Metro Ford Kansas City, MO.) to about $50 at some of the other dealers.
