General Automotive Discussion
Routing Spark plug wires
Old Apr 23, 2004 | 03:54 PM
mweeps's Avatar
mweeps
Need to clean up under the hood this spring. I installed FRRP 9mm wires last fall and I noticed the coil wire is long and just lays there anyway to get it up out of the way and does anyone make the 2 and 3 wire seperators like the factory style for 9mm wires?
Old Apr 24, 2004 | 08:20 PM
MustangGT221's Avatar
MustangGT221
Any place that sells wires has those separators, summit racing, jegs..etc etc.
Old Apr 25, 2004 | 02:48 PM
Andysutt's Avatar
Andysutt
Most local parts store's have them also.
As for the coil wire... I have 8.8mm and I relocated my coil to the fender for several reasons
1) Less heat on it
2) Coil wire not flopping around
3) Less wire mess on the motor, and less things in the way when you work on it
