Not a 360? 351/400?
Old Apr 23, 2004 | 12:16 PM
BillFX's Avatar
BillFX
Not a 360? 351/400?
When I bought my '71 F250, the owner said it had a 390. Last night I went out and got the casting number from behind the starter. When I searched that number, a couple postings on the forums said it was a 77 351c. Is that correct? Here are the numbers... D7TE A2B
Confused Bill
Old Apr 23, 2004 | 01:04 PM
rusty70f100's Avatar
rusty70f100
The D7TE was a service block for FE's and FT's. You probably do have a 390 that someone built using a service block they bought from Ford.
Old Apr 23, 2004 | 01:52 PM
Mike G's Avatar
Mike G
If I'm not mistaken, the 351C was not availalbe any longer in 1977, and they were not put into trucks...
If your manifold stretches halfway under your valve covers, which I would believe it does, you have an FE engine.
--Mike
Old Apr 23, 2004 | 03:03 PM
Winchester's Avatar
Winchester
5 bolts on the tapet covers also means it's an FE
Old Apr 23, 2004 | 04:19 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
As close as I can come is a D7TE-BA which is a 390 service block Like Rusty had mentioned..and no year given? Russ
Old Apr 24, 2004 | 09:12 AM
tomw's Avatar
tomw
If you want to really be sure itza FE, climb under it and look at the oil pan sealing surface, if it is flat, i.e. the pan is flat and does not have main bearing 'cutouts', its a FE.
tom
Old Apr 24, 2004 | 10:48 AM
scroob's Avatar
scroob
Very easy to tell. First, the intake manifold, as mentioned before. Second - 335 (Cleveland/M) blocks are the only Ford blocks that the thermostat housing bolts to the block. A thermostat on the manifold rules out a 335 block.
351C was last made in '74.
Old Apr 28, 2004 | 12:59 PM
BillFX's Avatar
BillFX
The info I got off this wensite...http://www.butlers-a1.com/fordm.htm shows it as a 400
Old Apr 28, 2004 | 02:04 PM
Mike G's Avatar
Mike G
So have you determined which motor it is?
--Mike
Old Apr 28, 2004 | 02:14 PM
BillFX's Avatar
BillFX
I'm going to have to go by the casting numbers that I found on that website. Might be a '76-'82 with a dipstick in the front of the block, or a '71-'82 with the dipstick in the oil pan. They also list the head casting numbers on that site too. I can't find what the stroke should be with a 400. I found the bore.
Old Apr 28, 2004 | 02:27 PM
Mike G's Avatar
Mike G
Becasue of the conflicting information, you may want to ID that motor by physical appearance. It would be tough on you to go to the parts store and get items for a 400 if you do have a 360.... Pop the hood and look at the motor. If the top radiator hose goes in the water pump, it's a 400 (see Scroob's info), if the hose goes in the front of the manifold, it's an FE. Then look at the intake manifold, if the valve cover bolts on the carb side go into the manifold, it's and FE.
Just wanting to keep you out of trouble.. --Mike
Old Apr 28, 2004 | 03:39 PM
scroob's Avatar
scroob
I didn't see anything on that website that identifies a D7TE block as a 400. In fact, the 351M/400 blocks all had a AE number.
There were no 351M/400 engines in '71 trucks. That's not to say someone didn't put one there later. The "correct" engine for a '71 would have been an FE. What's far more likely is that a remanufactured engine with a later year block was installed.
As I said before, if the thermostat housing is on the manifold, it's not a 400.
Old Apr 28, 2004 | 04:27 PM
BillFX's Avatar
BillFX
Look at the 9th and 10th from the end. D7TE A2B
I'm going to look at the thermosat housing location tonight.
Old Apr 29, 2004 | 09:06 AM
BillFX's Avatar
BillFX
I took a look last night. The thermostat housing is not on the intake manifold and the valve covers have 8 bolts holding them down.
Oh yeah, on the back of the aluminum intake manifold it says "Performer 400".
Old Apr 29, 2004 | 12:54 PM
scroob's Avatar
scroob
Then it's either a 351M or a 400. Hey, you got one with a good 4V manifold already on it.
There's a ton of stuff you can do to a 400 to really make it scream. Have a look at the 335 engine forum. Good luck.
